The Project insalatment no.2
stamfordian
28 Dec 2001
LINCOLINSHIRE
hi all, follows is the latest on the PROJECT.
The good ship....no name has made it to the butcher of the south lincs back garden,who has without favour to man nor beast ripped some poor soles hard work to pieces to measure up for reenstating a stern drive
He has mutilated the engine/gearbox and put all the goodies up for sale...buy them quick ....i,am going camping next week then off to espania for long awaited break from boats.
Day one of project (sat).
Takke off gearbox from engine
remove woodwork from rea r of boat
carryout first stage off hull repair...hole for shaft drive
http://www.arweb.co.uk/argallery/stamfordian
stamfordian
28 Dec 2001
LINCOLINSHIRE
Re: The Project insalatment no.2a
Forgot to mention that i,ve had a rethink on the sterndrive,the mercruiser unit i was going to use is not appropriate,so i,am going to keep it simple and fit an Enfield unit instead(parts etc easy to come by).
First credit of the project goes to Lancing marine they near enough buit the drive on the phone and expected nothing for it,excelent service.
aztec
10 Oct 2001
Poole Dorset
good bog standard choice, and you don't have to worry about the water via the leg bit either, just a hole in the bottom. if you get stuck for props give me a shout iv'e got a couple of different ones, you could try them and see which suits your application.
one thing to watch apparently is the hydraulic trim/tilt leg, iv'e been told that the cylinders are hard to get hold of.. correct me if i'm wrong. i think from older posts that you were on a drying mooring.. so the standard 130 side lift one would probably do.
anyway keep up the good work and good luck.
<A target="_blank" HREF=http://homepage.ntlworld.com/s.amos/index.html>http://homepage.ntlworld.com/s.amos/index.html</A>
