themount2
I've read much about fast downwind sailing but never really had the dangers of exceeding hull speed explained although I think I have gathered it leads to veering off course and possible broaching.
Scuttling back from Yarmouth to Gosport yesterday running/broad reaching with full genoa I realised that while the conditions were not THAT bad, they were of the type that causes this problem that I do not yet understand, if you see what I mean.
What actually happens? Is it the rudder is too small to have sufficient effect at higher speeds and gets overpowered by the speed thereby leading to loss of helm control OR is it the higher forces against the rudder at the higher speeds cause excessive direction changes above those normally expected for the rudder size OR is it something else?
Cheers
Brian
Cheers
Brian
