vjmehra
Does anyone know of any mechanics I can visit on the tidal Thames (not Chas Newens), I just want someone to take a quick look at our engine?
Hello All, I co-own this RIB and am bordering on feeling competent enough to fix this problem myself.
A blurry attachment shows our three spark plugs. The suspiciously clean one is the lowest. To my eyes, there wasn't much discernable colour (tan/black/white) on any of them, but there was a little "carbon-esque" deposit on the clean one. They're NGK B8HS-10's. I'm presuming this confims the diagnosis suggested here.
The solution, I gather, is to pull out the three carburetors, open and clean the float chambers (the lower bowl shaped part of each carb') with a fuel-soaked rag, then replace and rebuild.
The diagram is pdf page 51: http://motorka.org/doc/yam-remont-50-90.pdf
Rebuilding: I presume it's very important to rebuild with a torque wrench. I'm slightly concerned over how delicate the settings on "throttle arm" (the rod(s) connecting the three carb's, controlling the throttle), etc., when I reattach.
It's pretty fiddly in there from my first look.
Any thoughts or advice?
Much appreciated
Craig
