Thames - leave lock chambers full if going upstream
Old Crusty
28 Aug 2017
Due to low flows, the EA has requested that boaters leave lock chambers full when heading upstream rather than leave them draining.
That made sense when the walls were jet washed. The algae must have peaked by now.
With an empty chamber and in current hot weather conditions the algae dries in the sun, cracks and drops off if left long enough. Jet washing not permitted now due to elf n safety and bacteria in the river water mist that lockies have inhaled for years.
Also dries off the muck on the stairs - so less easy for boaters to slip off (as in an earlier thread)
Why cant they scrub the walls as before, no need to cause any mist to enhale.
On another note I see that the EA launches also have filthy waterlines now, shame on the skippers.
Excuse my ignorance, but why would that not be normal practice?
This subject has come up previously.
A lock should be left with the sluices closed on both sets of gates which means it will tend to fill or part fill.
The lock being full or part full means the earth pressure on the lock walls is resisted by water pressure and this reduces long term creep deflection of the walls .
If a pedestrian falls in a lock it is better if the lock is full as it is easier to get out and also easier to rescue the faller . Also possibly less injury done in the fall. In an urban situation where there may be more pedestrians and piss artists the top paddles might be left slightly up t make sure the lock fills.
However if the paddles are closed there is less risk of an object becoming stuck in the paddle.
A bit of green growing on the walls of no consequence and is no good reason to leave a lock empty.
I merely stated the custom and practise and the reasoning behind it. Potential dynamic reasoning has not been part of the thinking.
In the past, tail sluices have been left up to allow fish to escape the chamber.
That's not what the EA say. The normal practice, according to them, is to leave the bottom paddles open to empty the lock.
