Testing a transducer
The following assumes the boat's out of the water...
If you have a length of plastic waste pipe (maybe 2" dia and 2' long or so) try the following: cover one end with something like thin rubber sheet and place the other end over the transducer. You should get a depth reading about 4x the length of the pipe.
Danny
Well Done! This piece of info is a pure gem!!!
Just tried it on two suspect transducers and results were identical although it was nearer to 3 times the depth.
I used a piece of 2" waste pipe with a rubber glove stretched across one end and secured with insulating tape.
PS. Its even more convenient as no water required and worked with pipe lying accross floor!!
Wish I could claim to have invented the idea. I saw a similar test rig when I visited Nasa's service department a few years ago. The greater depth indicated should reflect the difference in the speed of sound in air and in seawater. IMS it's around 4x faster in water.
