winsbury
stumbled on this today... cant believe how many questions I got wrong !
http://www.bethandevans.com/quizlibrary.htm
There's a couple where I didn't particularly like any of the options but possibly because of the way they were worded, for example the one about getting water out of a crankcase which I think actually meant getting water out of the cylinders judging by the 'correct' solution.
Definitely some where they assert as absolute facts things that most people would consider a matter of opinion.
+1 Fuse or Connections...Definitely some where they assert as absolute facts things that most people would consider a matter of opinion.
It took several questions before I strongly disagreed with their answer, although there were a few 'it depends'...
You are on passage, close hauled and the wind is expected to shift forward in 4 hours, which is fastest?
•Continue steering directly toward the destination
•Steer close hauled
•Steer high but not close hauled
It depends on the distance to cover, but the first two options may mean that, as the wind shifts, you will end up directly to leeward of your destination
and have to cover the remaining distance in a series of tacks.
The third option means sailing lower than the course required, probably on a close reach, so you will sail faster. As the wind shifts, with a bit of luck,
you will be able to tack once and lay your destination directly. Probably more enjoyable, less work and might be quicker than the other two options.
Andy
I got all the provisioning right go figure, I know nothing about it and guessed.
•Steer close hauled
Andy
Yep, that's pretty good justification for that answer... However, in my head, I was planning to be in early for a drink, so my destination was only 45 minutes away. Why would I change course for a possible weather shift 3 hours after I'm alongside?
So interesting to take part, but without a whole hod load more detail, most of those questions come down to detail. There are far too many different boats on the water for anyone to tell me that two foresails will be quicker than a main and a foresail poled out on opposite sides.
Plus, pretty certain a right hand prop causes starboard kick at the stern, so the fastest turn is to port, not starboard.
So fun, but double check before you go believing every answer...
Maybe a bit of Titanicitus........Wheel /Helm I agree with you.
