nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
I've recently bought a new Whale Watermaster FW1215 fresh water pump ... My plan is to ... glue a small plywood board to the front of the foam, and mount the pump on that. My question is: what adhesive should I use on the board/foam/panel?
Update on this. I discovered that I had some 15mm thick Neoprene foam (eBay 261338185781) so I would do some tests. I cut identical rectangles of the foam: 38mm x 24mm, then stuck them between a piece of wood I had coated with a layer of Polyester resin, and a piece of plywood (very dilute varnished), both cleaned with Acetone. They were clamped to this with a 1kg weight each for 48 hours. The adhesives were:
Generic SuperGlue Gel (difficult to get an even spread, as seen in results)
EvoStik "Sticks-Like" All Weather Adhesive: http://amzn.to/1pJBKRx
Everbuild Lumberjack PU Adhesive http://amzn.to/1tx5HTS
Generic Epoxy Adhesive (Slow Cure)
This is the test rig:
As can been seen, the SuperGlue didn't spread evenly, so lost grip early.
All of the foam samples tore before the adhesive lost grip.
The scores:
Generic SuperGlue Gel (see above) 8.9kg
EvoStik "Sticks-Like" 11.9kg
Everbuild Lumberjack PU 12.9kg
Generic Epoxy 13.5kg
So at over 1kg per cm², I think this demonstrates that any of these adhesives are adequate for these substrates, as the foam is the weakest link.
I shot a video of one of them letting go, can post if requested.
