Tender Fender - Advice Please
Tam Lin
1 Sep 2010
Essex, near the R. Blackwater
What can I put around the wooden rubbing strake at the top of my GRP tender so that I don't mark the lovely new paint on my topsides when I go alongside my boat on its swinging mooring? Any ideas welcome, the cheaper the better! Thanks.
A rubber fender strip will e better, but nothing will completely protect the topsides. Probably the best way is to hang a fender blanket and fenders over the rail of the yacht and use the fenders to hold the dinghy off.
Rob.
Heating pipe insulation.
It doesn't look up to the standard of the last boats you sent me, they were examples of painted hulls as I was asking about the best technique to use. In the end I used a foam radiator roller for gloss paint and got a nice finish. Went out to the boat yesterday and made some marks on it - should have known better! It is just possible to read the sign behind the tender in your pic, "Private property, strictly no landing." Can't read the smaller print though.
Tillergirl - I didn't know about the place in Tollesbury, thanks!
I have some plastic irigation pipe screwed around the gunwhale of my tender but actually I make the little boat pristine in winter and end up repainting touching up by the next winter. If it is not my tender often it is someone else's or I have banged up next to a jetty or something similar. I figure you can't get to fussy about the topsides of a well used boat. olewill
Luckily, I have a license (sic)
The foam survived 5years and was still in reasonable condition when the new owner took it off to North Wales.
I did set about a refurb, but decided against it as the patchy paint gave the impression the boat was a wreck, and that matters when there are joy-riders about.
A three inch coir rope - Des Pawson in Ipswich will supply and teach you how to fit it perfectly (there is a trick).
http://www.despawson.com/index.html
Des & Liz Pawson
501 Wherstead Rd
Ipswich
Suffolk IP2 8LL
UK
Telephone +44 (0)1473 690090
I have found this both lighter and more durable than rubber fendering.
Went to his website which directed me to Classic Marine who only sell 40mm rope or 1 and a half inches.
