[2574]
I’ve recently found a source of used teak, to be precise the deck planking of the former RMS Windsor. It‘s here: Ocean Liner Reclaimed Burmese Teak Ships Decking . Trinity Marine
You’ll see from the pictures on their website that it’s in a bit of a state and needs cleaning up. It also has bolt holes through the planks every 600mm or so. The underside of the planking where it laid on the steel deck is stained so needs a heavy duty belt sander or planer thicknesser to get back to decent timber. Nonetheless I think it’s worth the effort.
I’ve been after some teak to build a new cockpit table, I didn’t want to use virgin timber, even if it could be sourced, and this reclaimed stock works for me. I‘m not entirely sure it is all teak, I wonder whether some of the boards are other hardwoods, perhaps mahogany, and because of the treatment the planks have had over the years on the deck it is impossible to determine them apart - so it’s a bit of a lottery as to what you might end up with. Nevertheless the result is pleasing for my job:
So, if you’re after some teak this might be an option for you.
Rob
Rob
