fergycool
I've just been hanging upside down in my boat and discovered some damp plywood. I located the rain water ingress to the screws holding the sliding wheelhouse door rail to the deck. It's loose and of course the track has then slightly moved and allowed water to get in.
The deck is ply covered with a thin layer of polyester fibreglass.
I'm pretty familiar with the West system and have used that to great success to repair other such areas. The plywood needs to be properly repaired, which will involve lifting the entire door rail up. The plywood will then need to then dry.
Trouble is my boat is in the water and will remain so until summer. It's nigh on impossible for me to rip up the rail and leave it to dry in this weather.
So..... anything that can get me to spring without this getting much worse?
Would Captain Tolley's Creeping Crack cure at least partially block up that crack? Anything else? Gorilla glue, which cures with moisture, along the crack? Any other bodges?
Thanks!
Thanks!
