30boat
N/A
Would there be any advantage in making them in Teflon?
... Glass is added to improve these, giving the typical white appearance.
Nope, go with Vesconite if you want to pay for a high quality bearing.
I once used a 39 cent, gray plastic hose barb, for a direct drive bearing on a one inch shaft, turning 2500 RPM. Lasted several years. No noticeable wear in that time.
Any soft plastic will work.
Hi SteveWhat size bearing are you after Nuno? I make bearings for the Vega out of a fantastic material (Vesconite). If you can let me know the dimensions (OD & ID) then I will see what I can do.
Cheers
Steve B
If you need a bearing quick
http://www.theplasticshop.co.uk/nylon-66-rod-40mm-to-60mm-diameter-1760-0.html
They send by return of post, the black is the grade for bearings, as it contains moly bisulphide, which gives it it's black colour.
Any machine shop will lathe it quick. A 250mm by 50mm rod cost me £10.50 plus postage.
Hi Steve
My arrangement is weird in that the P Bracket bore is imperial but the shaft is metric(25mm).The problem is that no cutless bearings (that I know) come in those sizes so the ones I've been getting are slightly undersize and have to be set in epoxy.As a result of not being pressed in the inside diameter is too large for the shaft.They don't ever last longer than a few months.I must launch on Monday so no time to fit one of yours but next time I haul out I'll measure the Pbracket bore and let you know.
Cheers
Nuno
Nothing unusual about your cutless. It is a standard size 1.5"od 25mm id fitted to many Westerlys. Available from any stern gear specialist or Trafalgar Yacht Services.
If you are getting a short life it suggests there is something else wrong. Misalignment is the obvious one, either engine to shaft or P bracket to engine centreline.
BTW if the inside diameter is too great that suggests you are using a 1" (25.4mm) bearing as cutless bearings do not compress when you fit them.
