Dave_Snelson
Hi Learned members - I have had an intermittent fault on my Windy 8800 since I bought it last August. The starboard motor (petrol / lpg) when cranked on the starter will start but when you let go of the key once the motor fires (and it does rev fire and up) the motor then stops. Clearly the ignition circuit is complete when the starter is being cranked but broken when the key is released. The other clues are that the volt meter and other associated instruments are dead when the stbd ignition is turned on and spring to life when the key is turned further to crank the motor. It does this on both gas and petrol. The port engine is unaffected.
The fault is now hard failed as there is no power to the guages unless cranked.
Any ideas please??
<hr width=100% size=1>Madoc Yacht Club
<A target="_blank" HREF=http://www.madocyachtclub.co.uk>http://www.madocyachtclub.co.uk</A>
Any ideas please??
