Techimpex Oven
Hi,
is there anything else I need to know?
Yep, if you screw it up you could have a bomb on your hands!
Take it to a professional, unless you want to risk a gas leak in the future. Failing that save yourself a few quid and take the risk...Rather you than me though.
Techimpex are italian so should be able to advise you of somewhere you can get it serviced in the med.
Failing that here's a contact for Techimpex in the UK: Penguin Marine 00442392465607
Hi,
Does anyone know how to remove the stove top of a Techimpex oven? Is it just a matter of removing the two burners, removing the screws in the 4 corners and lifting the top up (I presume the thermocouples will have enough ‘give’ in them) or is there anything else I need to know?
Thanks,
I gave up on mine and replaced the whole thing with a Plastimo. Techimpex is not the best designed bit of kit and difficult to get spares.
