superheat6k
I have had the teak transom on Billy Ruffian stripped of the failed varnish. Not sure what was used but it was very thick, very failed and resistant to Dillunett AKA Owatrol.
The pal who is doing the stripping for me has suggested I simply Oil the surface periodically. This would certainly be easy assuming it would need a repeat treatment every few months, but this would be simpler than the awful strip that has now had to be done.
The other options I am considering are Le Tonk, Epifanes, Semco Clear. The latter leaves the raw cut beauty and colour of the wood, but leaves it as a raw finish.
I will eventually be stripping the heavy and failing varnish layer from all the external wood trim - cap rails, side trims, etc. The most effective method is simply to sand the surface until clean. Fortunately the deck is not varnished and that will get quite soon a Wessex Two pack treatment followed by Semco clear - so is Semco everywhere the way to go ?
