Teak - has its uses
Portofino
10 Apr 2011
Boat- Western Med
Teak
Inspired my MapishM,s Passerelle fix it post I think I solved a longstanding problem .
Anchor ball fixation
Boat came with all the regulation kit , ERIB , life jackets all 16 diff sizes and an an anchor ball .
If we are on the edge of a pack and lights fading I like to use it esp in busy areas .
I know most are probably not fussed .
You can see the issues from the pic of the foredeck.
So I crafted a kinda stocks out of teak and remodelled the base of the anchor ball , put a hole in one side so,s the through wing nut bolt threads .
Finally it’s string wrapped under completes the security.
Feeling chuffed I then tackled the tender chocks , improving on the original s by mortise jointing some cross pieces to prevent it tipping .
Also contoured them to the hull of the tender using a template .
Made sure the fwd one was higher so it naturally drains with the bung out .
We like a clear none toe stubby bathing platform.
Sorry poor connectivity for direct pic uploads
https://imgur.com/a/dKtlzw3
nice!
next mod will be to fit a telescopic ram to the anchor ball so that it goes a bit higher, I tad low it is now, no?
:D
cheers
V.
PS. I also have the anchor ball as part of the regulation kit, never used it, I do turn on the anchor light at night though :)
Yes a lot of regulations kit .
I have a radar detector in a box under a saloon seat .Ticks a box for jobs worth I guess .
I need to work on a similiar way of fixing that , thinking end of the Passerelle and stick it up ?
