KevO
I've got some 6mm teak-faced ply to make up a new mounting board for the chartplotter in the cockpit. The end grain of the ply board will be joined to 6mm x 20mm teak lipping glued to the board with epoxy (with microfibers added). The front face of the finished board will be woodskinned. I intend to seal the back of the ply with SP106 epoxy.
Question: Should I also seal the ply end-grain with a thin coat of epoxy before bonding the lipping to it? I assume it will help to seal the end grain and provide a better surface for the thickened epoxy adhesive mix to subsequently bond onto. Should I thin the 'coating' epoxy mix to help it penetrate and give a smoother finish? If so... what with?
