Teak Deck Thickness
WilliamA
New Member
29 Jun 2014
I'm in the process of doing some deck and cockpit teak repairs and wonder if anyone knows what the original teak thickness would have been on a Rival 38?
Also which is the best yard Nr Chichester for a pull out and clean?
Many thanks
William
I wonder if you could find something here?
Teak Deck replacement. GRP or teak again? [Archive] - Yachting and ...
www.ybw.com › ... › Forum › Practical Boat Owner's Reader to Reader
Nov 22, 2010 - 34 posts - ‎15 authors
Is it possible/feasable and financially viable, to have a teak deck stripped off a GRP base and replace it with a GRP topping? If so at ... The last cosmetic deck replacement I carried out was on a Rival 41. ... 22-11-10, 19:38.
" I think I want... a GRP boat with a centre cockpit ... 35 posts 16 May 2013
malo 38 12 posts 25 Dec 2012
Teak Decking 23 posts 3 Jul 2012
1982 Oyster 41 88 posts 1 Oct 2008
More results from www.ybw.com
Teak Deck Questions - Page 2 - The WoodenBoat Forum - WoodenBoat ...
forum.woodenboat.com › Building / Repair
Jan 31, 2012 - 42 posts - ‎12 authors
I need advice on repairing the teak deck. ... Rebuilding Lynn Rival ( Rival 38 ) - Lay your own teak deckHaving stripped the old deck, made ...
DIY teak decking | YBW Boat Tests
www.ybw-boattests.com/content/diy-teak-decking
Rebuilding Lynn Rival ( Rival 38 ). Paul and Rachel Chandler source, saw and steam teak planking themselves. What sort and sizes of teak did we want. Deck
The thickness would depend on several factors. I doubt if a veneer on plywood would have been used, as per many continental boats. Next point to check is the teak deck screwed down, i.e. are there filled screw holes. If none then it would be a thin layer of 6 to 8mm that was glued down. If there are screws, then the teak would most likely be 10mm.
Out of interest our steel ketch had Dutch marine ply glued to the decks and teak screwed to it, the cruising weight was 14 tons. I had the teak decks removed in Trinidad and after removal the boat was two inches higher in the water. I picked up about two square feet of teak and ply and couldn't believe the weight.
