noswellplease
Thanks for the advice on 24th. I think that the main problem with screw plugs dislodging is basically that there is not enough debth for the plug to take a good grip. In most of the cases where the plugs are missing its less than a quarter inch to the screw head. What I'm wondering? If I remove the screws which appear to be very firmly bedded and replace with a slightly shorter screw then would I not also need to add some epoxy into the hole base so the new screw gets a firm grip. I then need to drill out a slightly deeper recess for the new plug, and hope that no further problems are encountered. The screws that I have tested seem to be so firmly embedded that it seems a bit foolish to be touching them in the first place. Has anyone actually encountered my kind of situation and how did they deal with it? Thats my dilemma. It would be easy to just glaze over with epoxy but that would diminish what is an otherwise nice teak deck! Russ
