firstascent2002
Hi guys,
I have a taylors cooker plumbed into a tank about 4 m away. I have just bought a second hand taylors heater that ideally I want to run it from the same tank. Is there a reason why I can't run both the cooker and the heater from the same tank using a t connector to split the fuel supply? Also If I do this then the heater will be about 7.5 M from the tank and the taylors guide suggests a max of 5 m. I have e mailed taylors with no reply. Any thoughts? It would be a pain to have to put in a second tank.
Second...if I do have to put in a second tank, I have a small paraffin tank but it is not pressurised. To buy the pump from taylors costs >100. I was thinking of drilling a hole in the tank a and putting in a inner tubeless tyre valve then pressurising with a bike pump (or even a halfords 12 v compressor with pressure guage). Any thoughts on wether it would work or other ideas?
Hope all your boat prep is going well.
Jamie
Jamie
