TonyBuckley
I stripped down my Taylors diesel heater and discovered most of it had fallen to pieces. Corroded and coked beyond belief. I have only used a couple of times on the new boat and it always burnt orange with not a lot of heat hence the service.
Just priced the replacement parts: burn pot, burner element, main stack and a couple of little bits. £450 quid! Seems a lot for what is basically pressed thin metal.
Should I dump and go for an alternative new heater or press on. It does look pretty and these parts will essentially make it into a new heater.
