boatone
I have two Tasman V3 Battery Isolators solenoids/relays (?) on my Broom 34. This morning found that although I can hear relay clicking for engine battery it does not make the circuit. If I press the manual switches on the isolator unit it works ok. It also switches off using the same key switch that should switch it on.
Anyone got these units? Is it likely the isolator has gone faulty or could it be a wiring issue?
