Tank monitor - connections to external device
cobolt
24 Nov 2008
Yorkshire, UK
Hi all,
I'm looking at the Gobius Pro sensor....I need an externally fitted sensor that will work on a stainless steel tank and this seems to be about the only one to achieve that.
It's purpose is to act as a holding tank "full" sensor...it will of course tell me this over its bluetooth app, but what I'm really interested in is hooking this up to a Raritan Smart Control unit. By doing that, a red LED will illuminate on our flush panel, and the automatic flush option will be disabled until the tank is emptied (manual flush/empty remains working).
The Raritan Smart Control has "float" and "common" terminals for connecting a sensor. From Raritan, there just needs to be a simple closed circuit across these contacts for the "tank full" light to illuminate. No voltage should be applied, the two wires simply need a switch in-line, which should be open normally, and closed when tank is full.
Now the Gobius Pro allows for connection of external interfaces. The Gobius Pro has 4 wires from it :
Red - 24V +
Black - Battery -
Yellow - for external sensor use (tank empty)
Green - for external sensor use (tank full)
To connect an external device (they cite things like relay, buzzer, lamp) according to their instructions, I would use the red and green wires.
Considering the red wire is also 24V+ I'm wary of connecting these to the Smart Toilet Control, for fear of pumping 24V somewhere it shouldn't go.
Can anybody help me in understanding how/if this could work? It seems to me that rather than just being a simple switch, the output of the Gobius actually feeds battery voltage to whatever the external device is...which I guess is not good in my requirement.
If that is the case, is there a way to turn that powered output into a switch signal for the Raritan unit?
Thanks Ben
prv
29 Nov 2009
Southampton
Looks like the yellow or green wire goes to ground when the relevant condition exists.
If you connect the coil side of a relay between the red and green wire, then the switch side of the relay will look like a switch to the Raritan panel.
