dgadee
Forgot to get talcum to thicken some gel coat when I was at my supplier. I can't see any reason why I can't use stuff out of the chemist. Can anyone tell me differently?
Yes, using flowcoat. Don Casey is my source for thickening suggestion - in case one coat isn't sufficiently thick. Page 109 of sailboat refinishing. I am adept at grp but this is first attempt at this technique.
No one has suggested everyday talc differs from non perfumed, so will give it a go.
Have used plain flour to thicken epoxy for years - no ill effects
Article by Steve Smith, Chemist.
.....The net result of adding talc, limestone or other mineral fillers or pigments would be a dramatically enhanced tendency of the hull to show GRP laminate deterioration of the type commonly referred to as osmosis. There are three reasons for this. First, special mixing equipment is required to mix powders with liquids without mixing in fine air bubbles. This is routine for paint manufacturers but not for boat manufacturers, thus many fine bubbles in the resin would be expected. These bubbles are additional voids into which water can diffuse, thus creating osmotic blisters. Second, adding mineral fillers would interfere with the ability of the resin to wet out bundles of glass fibre, allowing voids in which water accumulates, hastening chemical decomposition of the GRP laminate. Third, mixing limestone (calcium carbonate) or other water-soluble minerals will cause osmotic blisters as the limestone dissolves in the water that is drawn to diffuse through the laminate.
Normally, no manufacturer is likely to admit to anyone they are doing this, much less doing it only to save money. There is no good reason for it. ….. …The chemical consequence of mixing powdered limestone, or any water-soluble mineral for that matter, into GRP in a boat hull is to guarantee that there will be osmosis blistering and deterioration, as the water diffusing into the GRP will dissolve the limestone just as underwater seepage dissolves limestone, creating caverns with stalactites and stalagmites.
© copyright 1972 - 2009, The Brain Trust, a California irrevocable trust,
reprinted with permission Steve Smith The Real Story of Osmosis Blistering, Treatment, Cure and Prevention. March 2003
