Lakesailor
OK Men,
My recently acquired little clinker dinghy has been out of the water with a bare bottom for 2 years (at least).
I've used 2 coats of International UCP (Universal Clear Primer) on the bottom and a coat of International Original Varnish on that. (Not recommended for below the waterline, but I am going to dry sail the boat).
Here is the quandry. As the boat will need to take up quite a bit, would I be better having her in the water a bit before applying any more varnish (3 coats is the recommendation)?
I'm thinking that will allow more wetting of the wood at the plank edges. If I load the clinker joints with varnish it will probably only crack as the wood moves anyway.
When the boat has taken up I could dry it a bit and add more coats.
What do the team think?
