Seagreen
I'm an odd little problem. Cleone is very...bad at tacking. At low speed in light airs, she will swing into wind and then stop, and I either have to back a headsail and hope for the best, or put the engine on. Not desirable. In a decent breeze, she will carry her way round but still takes her time going through the wind. In any sort of short head sea, she will more than likely just be stopped.
So, Cleone is a gaff yawl, with a straight stem, and long straight keel. She sets a jib and staysail, the jib on a long straight bowsprit. Gaff main and small gaff mizzen, set well aft.
It doesn't seem to make much difference if I set the mizzen or not. I usually only set the mizzen in light airs going to windward. I've tried various combinations of tacking the jib first and then the staysail, and vice versa. She does have a very fine entry and I did wonder if boring a relieving hole or two through the stem to allow the water pressure to flow easier round the stem might work.
Any suggestions? Once sailing free, however, she goes 'like shot off a shivel'...
