Plevier
I need supports for the drop leaf of a table. I can't use the simple solution of swing-out wooden quadrant brackets because the clearance behind the flap when down is only 7mm, I can't change it, and wood would need to be thicker than that. I could use swing-out quadrants made from steel wire, I have seen these but haven't managed to find a source.
Alternatively I might be able to use over-centre locking folding struts but again I haven't found a source.
Anyone know a source for either please?
(Why? My table has one drop leaf and one fixed side. The drop leaf is supported by slide out tubes that when closed project below the fixed side. I want to make the fixed side into a drop leaf so need to change the existing drop leaf support.)
