mickywillis
Evening all,
Having issues with connecting a Quark QK-A015-TX VHF Aerial Splitter to an Icom MA500TR AIS Transponder.
When connected via the splitter, after an initial transmission of the AIS signal (indicated by the green LED on the rear of the splitter) the Icom flashes up a warning " Antenna Malfunction High VSWR" If I reset all the equipment, the same problem occurs again. The Icom has a diagnostic screen and when displayed, the antenna test shows NG (no good!)
If I connect the Icom directly to the VHF aerial, it all works OK, no errors or faults detected. I have a Cobra fixed VHF and this transmits and receives OK when connected to the masthead VHF aerial ( a Vtronix Hawk, fitted about 6 years ago)
Could possibly be an issue with the connecting patch leads, so need to test those or replace them.
If these dont prove to resolve the issue, I guess that I need to get a SWR meter and do some fault finding?
Is it possible or OK to use a SWR that was originally designed to be used with CB or Amateur radio equipment? Something like this: Trans Swr And Power Meter? Cb Radio/ Ham Radio? | eBay
If not, can you direct me to a suitable unit please?
Thanks.
Thanks.
