BabaYaga
I would be grateful for some advice on fusing:
The wire supplying the distribution panel on my boat has no dedicated fuse. Instead this bit of wiring is protected by a 80A ANL fuse installed close to the domestic battery bank positive take off terminal.
While this fuse is sized for the maximum alternator charging current (70A alt), the aggregated load through the distribution panel is nowhere near as high.
I am now thinking about putting a smaller fuse in the distribution panel wire, probably 30A, but with the option of increasing in the future if needed.
The wiring itself is somewhat oversized – the charging circuit is 35sqmm in order to minimize voltage drop – the wire to the distribution panel is 25sqmm (for reasons I no longer remember).
1. Would such a fuse be a good idea and a benefit to safety? (The distribution panel has both positive and negative feeds, so shorts in this area are not totally unthinkable)
2. What type of fuse would be suitable? I find the ANL type rather bulky, but would prefer to connect to the holder by ring terminals. What do people use for the 30 - 50A range? AMI? Maxi? Midi? Strip link? I find the offerings a bit confusing...
