Suzuki SMG4 gauge inversion
PhBST
New Member
8 Jun 2025
Hello
I bought a boat equipped with a Suzuki multifunction gauge. When I add fuel to the tank, the gauge tends to decrease rather than increase. I contacted the dealer to find out what I should do, and they told me the problem was related to the gauge's configuration. Despite my research, I couldn't find the information. It would be helpful if you could explain to me which menu I can use to change the direction of the fuel gauge.
Thank you for your advice.
Have a nice day.
It sounds like you need to change the setting for the fuel sender from US to Europe or vice versa. The resistances are reversed on the senders. European: Full 190 ohms, Empty 0 ohms. US Full 30 ohms, Empty 240 ohms. If you have a SMG4, go into Menu, then select Tank Calibration.
