aussieinvader
New Member
Hi Guys and Girls , Just joined your forum and thought I would say Hi . Have been out of boating for quite a few years but am now slowly getting back into it .
I do have a couple of questions ......
I just picked up a cheap Suzuki DT4 (1988 I think) but it wont idle ..... It will start on choke and run on throttle quite happily . I have stripped the carb down and cleaned all the crud out with an ultrasonic cleaner but still no luck however when I partially cover the air inlet it will idle ... is this motor supposed to have a small air cleaner/restrictor on it as there is no sign of one ?
Also the tell tale starts and stops while running at high revs and I am leaning towards a damaged impeller , any other thoughts ?
Todd
Todd
