A
Anonymous
I have a Suzuki DF6 2005 model. I grounded the prop on some concrete this evening which resulted in me being able to get back to the yacht on around 30% power but any higher, led to high revs and slip.
I have removed the cotter pin from the prop nut -- which was fine. The engine is on the tender and it is very difficult for me to remove it at the anchorage as Mrs L does not have the strength to handle it from the tender.
I see from the user manual that there is a component called a "stopper". Is that effectively a shear-pin that I have probably sheared? If I can get a spare, should I be able to replace it easily by reaching over the stern of the tender, or should I get the engine on board?
If I cannot obtain a stopper locally, is there a work-around? We are at anchor and some 1nm from the harbour.
Is the slip deliberate and constant -- i.e. can I run the engine at low power indefinitely, or was I just lucky to be able to get back to the yacht? I don't really want to motor back in to the harbour in adverse conditions, to find that the drive fails entirely.
Many thanks
Many thanks
