Billows
I have determined that mine is a 2012 model. I have looked up the assembly detail diagrams from Browns point.
http://www.brownspoint.com/store/pc/BP_AP_AssemblyDetail.asp?ID=8216
This indicates there is a fuel pump but I can't see it on mine. The cock seems directly connected to the carb
I am attempting to clean the carb also
http://www.brownspoint.com/store/pc/BP_AP_AssemblyDetail.asp?ID=8432
I have taken off the cover ( 20). I assume I undo the screw (16) I can see proud of the surface to take out the pilot jet (15) for cleaning. Will the jet just fall out or does it need unscrewing too.I can also see two small brass coloured items inserted in the surface which I assume are (17) air jet and (18) pilot air jet. What do I do with these. I will also take off the bowl to clean the main jet (3)
Hoping this will cure the slow idle cut out and the occasional falter on full power. Spark plug is a nice biscuit colour. I also know about the hidden low running adjustment. I may access that also.
