Suzuki 2.2 HP outboard runs for a minute or so then stops
Avocet
3 Jun 2001
Cumbria
Any thoughts as to what might be wrong with it please? It's old, but hasn't done many hours. Always starts first or second pull. Runs for anything up to a minute and then just dies. The revs drop off as if it had run out of fuel. When it does this, it nearly always re-starts straight away. It's certainly not seizing (I can turn it over easily as soon as it stops). I assumed it was the tank vent not letting air back into the tank, but I tried it without the filler cap on today and it did the same thing. I've had the carburetor bowl off an there was no water inside. I drained it and mixed up a fresh batch of fuel too. Still no joy.
I had exactly that with mine - also a very lightly used Suzuki 2.2. It turned out to be the spark plug even though it looked perfect and was showing a good spark when tested. I had already replaced the plug once which solved it for a couple of short runs but when the fault returned, I discounted that as the problem. Eventually a dealer tried another new plug and it has been running fine ever since. Get two new plugs and keep one as a spare.
Filter is ITYWF in the tank as part of the fuel tap assembly
As Dipper suggests often a good plan to change the plug.
Thanks all. Hadn't thought of the plug (it's relatively new) but worth a shot, I guess. Pretty certain the filter in the fuel tap is OK, because there's a pretty rapid flow of fuel through the tap when I take the hose off the carb and just let it run into a jam jar. Haven't been brave enough to take the carb to bits, but I guess that's the next thing I ought to try after the plug.
If it is not used much, it may well be gummed up. Strip the carb, and give everything a good soaking in carb cleaner. My guess is a problem somewhere around the float area.
If it was jets gummed up it wouldn't start or run well. The fact it lasts a minute points to the needle valve.
Had a similar issue with a 3.3. Running for a bit then restarting implies either feul or plug. Plug easy to replace. If that does not solve it as the above posters have mentioned, it is most probably a feul issue.
Mine was a problem with the needle assembly ... replaced some parts (that looked ok) and now it runs. The needle and jet it fits in are precision parts (I know it is a 2Stroke so not that precise) and mine had corrosion (salty white stains)
