Suunto compass - spare screw sought
Gubbo
17 Jun 2001
Woodbridge
www.sailpast.co.uk
Hi,
I've managed to sheer off one of the small pivot screws from my suunto K-12 bracket compass.
Unfortunately Suunto no longer support these old models so they can't supply one.
Does anyone have one in their spares box? (I'll happily pay for it) Do you know of a compass repair business that may be able to help?
Here are a couple of pictures to show the part I need
Regards
Richard
prv
29 Nov 2009
Southampton
I'd have thought any old bolt of the right size would do the job. Perhaps best find a brass one to avoid affecting the compass.
Failing that, anyone with a lathe and a set of dies ought to be able to make one easily.
Hypocacculus
15 Jun 2014
Planet Earth
A clockmaker would be able to make one for you easily, or might have something suitable in the box of screws all horologists hoard. FYI that is called a shoulder screw.
fergie_mac66
28 Jun 2009
south yorks
If you can not get one. Railway modellers shop will find what you want or someone who can make it in brass . Failing that you can use a brass screw full length and get a foot of brass tube get right dia cut to length will do the same job .
Heckler
24 Feb 2003
Hi,
Regards
Richard
View attachment 43457View attachment 43456
Put a ruler along side it or measure the diameter of the bolt. It will be a bog std metric bolt.
Stu
prv
29 Nov 2009
Southampton
Is it fastened with a nut? Yes = bolt. No = screw.
What if it's not fastened at all, and just sitting in a box on the shelf?
No way of telling? Schroedinger's Fastener?
(I thought the difference was whether it was threaded its whole length, or only at the end.)
prv
29 Nov 2009
Southampton
So did I, but I looked it up before posting.
In that case, my question is a serious one. How do you know if it's a bolt or a screw, if it's just sitting there on its own? Perhaps tomorrow I might decide to put a nut on it - does it then turn from a screw into a bolt?
Seems bloody silly to me.
prof pat pending
3 Jun 2013
Oxfordshire
This'll be interesting on an international forum
Heckler
24 Feb 2003
Exactly, you know what I meant and at this point all that is needed to be known is the diameter of the thing. From there one could search for the correct thing OR given as this is PBO, give advice on how to make something to make it whole again!
However the old pedant decided to make mischief and someone on the side has jumped in!
Stu
VicS
13 Jul 2002
The unqualified term "bolt", a bog standard bolt if you like, refers to a hexagonal headed and partially threaded fastener with the unthreaded shank the same diameter as the nominal thread size.
The similar item fully threaded is known as a set screw, although I have known them to be called set bolts.
The important feature of the items in the OP compass is that they are shouldered. The unthreaded potion is a larger diameter than the thread size and has square undercut shoulder which tightens against the inner gimbal ring and provides the pivot for the outer ring.
A standard bolt would be an unsatisfactory substitute for two reasons. Firstly it would not tighten satisfactorily against the inner gimbal ring and secondly because with a shank the same diameter as the thread it would be a lose sloppy fit in the outer ring.
Mostly fasteners with heads other than hexagonal heads are called screws although there are numerous exceptions. Coach bolts immediately come to mind.
Heckler
24 Feb 2003
Hi,
Regards
Richard
Richard
Whilst the children pedants squabble about definitions of hardware, could you measure the diameter of the thread on your screw and post it please?
Stu
Hypocacculus
15 Jun 2014
Planet Earth
Richard
Stu
If you are thinking of making a replacement, you'll need the diameter and length of the unthreaded section too. Because it's a shoulder screw the unthreaded section is wider than the thread so two diameters have to be cut on the blank.
That is why the fact it is a shoulder screw, not any other type of screw is important; it's not just pedantry. Anybody who makes stuff knows that the devil is in the detail. If the shoulder isn't made wider, the compass will rattle in its mount.
