Survey on my first yacht - Beneteau First 26
JonoSlatter
22 Jul 2002
Bath.
Hi,
I'm in the process of buying my first yacht - a Beneteau First 26. 1986
I've been looking all summer - and this boat felt perfect - really well looked after in and out. But...
Being new to this I'm a bit alarmed at the surveyor telling me that the moisture readings below the waterline are high - 20+ using a Sovereign Mositure meter. (5 above the waterline) His advice was that no action should be taken - but an osmostic condition could occur at a later stage. There's no signs of anything at the moment - "the gel below the waterline was found to be visually in good condition."
I understand that the boat has been in the water for the last winter - maybe more, so could this be the reason? She's lying in a drying out marina so sits in the mud for quite a bit of each day. I am intending to sail the boat until about November and then winter her ashore in Poole,
Wondering what you guys think (or girls) ? Should I be nogotiating for a reduction due to this.
Thanks for any thoughts.
Jono
PeterGibbs
3 Sep 2001
N London, and boat in Suffolk
Problem is twofold:
1. you might get symptoms whilst you are the owner but this won't mean the boat will sink - it's just a worry you'd rather not have!
2. when you come to sell, most prospective buyers will back off or demand big price reductions if the relative readings are this high. A real downer!
Personally, I'd d find another boat in this class and pass the problems by.
PS - there is always a differential in the readings between the hull sections above and below the water line; Moisture levels are not absolutes, only relative readings - as you probabaly realise. And the rudder will always have the worst reading of all - this would not normally be a reason for rejecting a boat, otherwise no one would buy second hand and that clearly is a fallacy!
Peter Gibbs
