steveej
I went to see a 2003 sun odyssey 32 today with a lifting centreboard that swings up between two minature bilge keels.
When lifting up the sole boards to check the bilge, there was what appeared to be lots of epoxy filler around the inner moulding.
Over the past few months I have also seen all three sun odyssey 26's currently on the market with the same keel configuration. They all had the same issue. I cannot believe it is a factory job as they are all very DIY by the looks of them.
Can anyone highlight to me what the issue is here.
Is this from drying out and the boat pounding on hard sand in swell with the result being delamination of the inner moulding from the hull? Is it structural? The bolts are in a square configuration to hold the mini bilge keels and what is effectively the grounding plate to the hull.
Great boat but it also needs new sails and a complete re-rig (running and standing) any idea of ball park costs for these?
Cheers
Cheers
