richardabeattie
I have a Yanmar 2GM20 and the recommended oils are 15W-40 for the sump and SAE 30 for the gearbox. Can anybody tell me why they need to be different? Would it be so very wrong to use 15W-40 in the gear box?
This is purely surmise as I'm not altogether familiar with the Yanmar gearbox. Many gearboxes use either a plate or conical metal-to-metal clutch and this will slip if using multigrade oils.
This is purely surmise as I'm not altogether familiar with the Yanmar gearbox. Many gearboxes use either a plate or conical metal-to-metal clutch and this will slip if using multigrade oils. I made this mistake with an old Albin installation and had to put flushing oil in the box and tug at the mooring for half an hour slipping her in and out of gear before refilling with the proper stuff. Straight grade oils are sometimes available from supermarkets but I got mine from Morris (the oil supplier, not the car manufacturer).
Rob.
Your question caught my eye because I've been doing something similar for a good number of years. The oil specified for my Bukh 20 is SAE30 for both the engine and gearbox. Having established that 20/50 multigrade would be ok for the engine, I've been using the same oil for the gearbox as well.
Relieved, but not surprised to infer from advice so far that I'm doing nothing wrong...
I have a Yanmar 1gm10 with a KMP2 g/box in my small sailboat and I was unable to get a 40 grade CD API oil and had to settle for a 15-40 Castrol CRB TURBO API CH-4SJ ,but I live in the Caribbean an Yanmar recommends 40 grade for my temperature zone Should I change it to a 40 grade when available or leave well alone
