Can anyone recommend a suitable AF for a new thru hull depth transducer? Can’t use our usual solvent based stuff apparently. One brush worth would do it so don’t want a mahoosive tin that will last me 25 years
I found the Marlin Eco transducer antifouling to be rubbish; water based solvent free and completely ineffectual, whereas I have slopped thick dollops of Hemel tiger xtra onto various skimmer and through hull transducers without issue. I even used the really aggressive solvent based stuff that used to be sold in Greece (colloquially called Farmaki or Poison) for many years on a couple of transom mounted skimmer transducers on a sports boat.
Could you try a coat of primer as a barrier coat and use your normal AF?
