Neal
My 1985 vintage Volvo runs sweetly, though a bit smokily. It starts instantly when warm, and after a few seconds turning over when cold in a UK summer. In the icy cold snap last week, it started easily after I'd squirted some lube oil onto the cylinders.
That's the good bit.
The bad bit is that, when the engine runs contiuously for long periods (say 40 hours), the bilges get a bit oily.
There seem to be two sources of this oil:
- from behind the flywheel. I guess there's a crank shaft seal that's weeping
- a small pool of oil collects under the air filter. There's a pipe from the rocker box to the the air filter, which is black with oil mist.
Oil consumption is almost negligible as measured on the dipstick - but a small volume of oil makes an unsightly mess.
My question is: do I have a real problem, or should I just invest in some rags and bilge cleaner and live with it?
My mechanical engineering skills are of a low order. I've pulled engines out and refitted and re-aligned them, but never undertaken a rebuild.
Any suggestions warmly welcomed.
