dunkelly
Anyone got suggestions as to how to remove a stuck fast prop on a macwester . i have tried heat and tapping all round , so far with no luck
Have you got a puller on it? If yes, wind it up tight and then hit the boss with two opposing hammers simultaneously.
sadly dont have a prop puller , i have pullers that ive used on other boats i have but there isnt enough room to get even the smallest one between rudder and prop .
And heat it
I always tie mine securely to the P-bracket, wind up the puller and then dribble small quantities of near boiling water over the prop. I've been lucky so far as it usually just flies off without so much as a tap.
I only did it once without tying it to the P-bracket and it went quite a few feet with a big bang. I now tie the prop and puller with a short piece of rope. Zero chance of removing mine without a puller. I did try heat and hammer technique years ago with little effect. A plate with a slot cut in it can be a good way to get some grip for a puller.
eBay can be a good source of really old, solid kit. Usually a result of a clear out when someone's grandfather moves to smaller accomodation (sometime very small). My puller is massive and much stronger than new ones. Ditto with 3' long crimp tool and 3' long stilson (I tend to err on the side of overkill).
It's been said above, however it's important to understand the order in which things happen
(Some plusgas the night before ain't a bad idea)
-Puller on, wind it up hard (you might need a piece of scrap steel to protect the end of the shaft)
-Heat it
-It's the action of hitting it with the hammer(s) that hopefully leads to the BANG and off it comes.
Don't expect it to start sliding slowly off just with the puller. It's the shock load from the hammer once everything is wound up super hard that will ping it off in one. All you need to do is hit the boss perpendicular, don't worry about hitting it in the direction you want it to move, and don't hit the blades!
You can also slack the nut off, but leave it on the shaft, and put your scrap steel across it. Saves any damage to the threads and stops the prop flying off. A bit like removing a car steering wheel and avoiding the smack to the face with it as it comes off![]()
Don't use one hammer.you need two and hit the boss simultaneously from both sides
.Your not trying to hit the prop off the angle of the hammer blows should be at 90 degrees to the line of the propellor shaft.
I have seen this work without pullers on a prop declared to be totally stuck. Clearly heat and wd40 etc will help but it's the shock waves that will get it off.
