Stupid, stupid, stupid!!
ailsaboat
Active Member
18 Dec 2003
I unstepped the mast while doing some fairly major steel work on deck. While working i remembered to clean up the grinding dust so as not to stain the paintwork(clever) but forgot about the mast 6 feet away alongside the boat(stupid)
Now my mast has rust specks along most of its length.
I have used phosphoric acid to remove rust stains elsewere and still have some left. Is Phosphoric acid safe to use on anodized alloy, or does anyone know of a better product for my mast?
Not sure about it but would "Y10" work? Available in chandlers, it is a gel that will remove almost any type of rust stain from GRP.
I had the same on some aluminium window frames fitted temporary to the cabin sides of my new steel yacht. I used one of there green kitchen sponge, washing up liquid and elbow grease.
Came up a treat.
"less harmless"
? sounds confusing
In answer to the original question - you should be fine with phosphoric acid on aluminium. Coca Cola contains significant quantities of phosphoric acid and is packaged in Al cans.
