PhillM
I have a Johnson 600 GPH pump like this one:
http://www.go2marine.com/item/199105/ultima-bilge-pump-600-to-1-250-gph-12-volt-32-47258-003.html
Its connected to a switch that has "auto" and "manual". There is about an inch of water in the bilge. Set the switch to "auto" but the pump doesn't seem run. When I press the switch to manual, the pump seems to run but no water leaves the bilge.
I lifted the pump out of its clips and checked for debris, opened the pump up and looked around the impeller and it was clear. I unscrewed the pipe and checked that wasn't blocked at the pump end. Ran out of time and so just manually pumped the bilge clear with the other pump.
I'm going down again tomorrow to take a look. I appreciate this could be my entry for stupid question of the year, but anyone got any suggestions?
