Can I exchange the flax packing when my boat in the water, someone told me I can go in a water use a towel to clogged the hole where the shaft go thougth the hull and take a time to change the falx packing. With 22mm shaft what size flax do I need and how to do it. Why the flex wear down so fast only last 6 months (bend new stuffing box come w/flex) I can't tighen anymore and the water still drop in when the engine off. I have a plactic stuffing box w/two bolt , one on each side to hold it down. I made a mistake to loose those bolt and tighen it back (pls. don't ask me why. I knew I was worng.) Thank you for help.
