Stuffing box service - how to
Must be the stuffing box season. I'm just about to do mine and by fortunate chance have obtained graphite packing. I was very pleasantly surprised at how easy it was to remove the old packing and also how remarkably intact it was after at least 20 years use!
just a smear on the shaft, "just" tighten the compression collar (& do not over do it) & turn the greaser until slight pressure is detected. run the engine in gear & make sure the stuffing box isnt running hot or leaking. adjust collar as req.
mine doesnt run hot,leak or spread grease about the engine box
quick tip from a marine engineer friend about stuffing box and what is hot and what is not.......if you can keep your hand on it, it's not hot. unless some of the experts know better...........but I've repacked stuffing boxes a couple of times and never had a problem
With PTFE at high revs (2000rpm) mine was way beyond too hot to touch.. it burnt my fingers... I'm surprised it wasn't smoking!!!
