Peroo
The outlet on our Raritan head is no longer working as it should. To tackle the problem I’ve tried to close the outlet thru-hull before tackling the Raritan head but it is stuck open. The outlet from the Raritan has a Y valve in place to route waste to either the holding tank or directly to the sea via the thru-hull. The Raritan outlet and the pump out line from the holding tank both have an anti-syphon inline. Pumping from the holding tank routes waste through the same thru-hull as when discharging directly to the sea.
We are in the water and live aboard – I have tried hot water over the ball valve, tapping with a hammer and penetrating oil to try and close it before tackling the Raritan – I suspect something has failed in the pump-out side of things as water can be drawn in, it’s just nothing is pumped away and there is no “pressure” when clearing the bowl indicating a blockage somewhere, to my mind anyway.
Question:- 1. do I continue with boiling water and/or penetrating oil to try and close the thru-hull assuming that the cone in the ball valve has seized at this time? If so, is this likely to be days or weeks?
2. can I be confident that, with the anti-syphon in place on both exit lines, that I can tackle the pump anyway – as the thru-hull is stuck open, at least I may be able to resolve the Raritan problem leaving the thru-hull for another day? I may get some residual waste water in the boat as a result of disconnecting the outlet hose. Not ideal, but a part way forward.
3. do I haul-out to tackle the thru-hull and the Raritan?
All thru-hulls were removed and replaced/refurbished in 2011 – all are ball valves and are closed when leaving the boat for any length of time. Last time they were operated was in June this year – only this Raritan outlet thru-hull is stuck; however it is one of the most used as we are in the water and living aboard full time. [I now “get” the “monthly” checklist and yes I have been remiss!!!] All thru-hulls on the boat are below the water line.
Ideas, suggestions, guidance and thoughts most welcome – have I missed any other options?
