Does anyone know what these are? Couple of cm long and filled with a gel, they came with a Garmin chartplotter. There's no mention of them in the handbook.
they are 3M butt connectors, probably UR2 see farnell you push wires unstripped into holes and crimp by using pair of pliers on the red bit. Just bought a box so I can sort out some of my Nema wiring.
Just poke the wires in the holes ( don't even try to strip the insulation) and squash them with ordinary pliers or even teeth ( the gel sqeezes out and doesn't taste nice!) or if you are really posh then the proper pliers - I would beg to differ with Charles, these are not necessary, unlike crimping tools where a cheap tool is worse than none...)
I am pleased to hear that they are being provided - many an expensive electronic array has been let down by poor connections - usually of the 'chocolate block' variety.
They're designed so you don't need a special crimper. Pliers better than teeth as you can apply even pressure to the whole crimp. You could try using a small vice as it's easy to apply even pressure slowly so you can see when the correct amount of "crimp" is applied - but don't over tighten!
