Babylon
I have a Simrad RT64 VHF (a few years old) which is behaving quite strangely.
With the antenna properly connected, it can only make and receive transmissions at very short range (ie from a marina berth to the marina office) but not further afield. I have checked that it is not the antenna that is the problem, by re-testing it with the emergency antenna rigged and connected - and got exactly the same problem.
With the antenna DIS-connected however, it receives transmissions from further afield (eg coastguard, VTS, other vessels)! I haven't however tried to transmit from it in this state, as I'm worried it might damage the unit further.
In both of the above tests, I also used my handheld in parallel - which worked perfectly despite being operated from down in the cabin.
Is this a common problem, what might be causing it? Can the radio be properly tested and repaired? (I don't want to buy a new DSC VHF if I can avoid it.)
