Strange oil leak Yanmar Saildrive SD50
bugs
14 Jul 2003
Galway
I have oil leaking where the saildrive meets the hull. It is weeping from between the large circular flange that is bolted to the hull.
I assume it is leaking from the leg and making its way out at this point. At first I thought it may have been engine oil dripping from joint of the flywheel but its got that very distinctive smell of synthetic gear oil.
Is this a difficult repair? Yanmar 4JH3 39 hP with SD50 leg.
Are you 100% sure you havent just lost the O-ring from the yellow filler plug and oil is blowing out when the gearbox warms up and is running down the back of the gearbox.
Its happened to a few on here and is sometimes difficult to diagnose until you know about it.
o-ring
I wish :-(
I scrubbed it all clean and watched carefully.
It looks like I will need to dismantle the leg/hull flange.
Have youtightened the flange bolts to the mfgs recommended torque? might cure it if clamp bolts are slack?Sorry not a yanmar owner, have a volvo 2030 with saildrive.Probably not the answer, just trying to help!
