tim_ber
I bought this 12volt LED to investigate.
Powered from 0V upwards, the top two leds light firstlly and then the side panels light up as 12V is reached.
I took the resistor out so I could run it from a lower voltage source (or so I thought).
The resistor was on the negative leg (that surprised me - should it?)
BUT the biggest surprise was that once I managed to solder it all back together, the side panels would not light at all.
No circuit board can be seen.
Those little 301 things, are they inductors or something? Is that why this will only work with a 12V supply?
Hope photos look ok.
