Iain C
The other week I serviced my engine, and changed the shaft seals and impeller on my water pump (it was missing a vane, which I recovered from the heat exchanger). It's a Johnson unit on a Lombardini engine. I now have a bit of an odd problem.
Usually, if I start the engine, and the boat has either been just motoring (say from club pontoon to swinging mooring etc) everything is fine...the engine starts on tickover and straight away I get a good stream of water both from the exhaust itself and the tell tale. And it doesn't matter if the engine has not run for a couple of weeks either...all is well.
However, if I go sailing (and I wonder if heel has something to do with it) when I start the engine I get nothing. The only way to get her blowing water is to rev the engine quite hard...you see the strainer bowl fill and after a few seconds she's blowing water again. However, I need quite high revs to "prime" the system...starting up on tickover isn't enough.
EG, started the boat on Friday after 2 weeks sat on the mooring...all good. Went to the pontoon for a few hours, started again, all good. Motored out of Portsmouth harbour and then sailed down to Lymington (upwind), and guess what, started to enter the river just a few hours later and no water until I revved hard. Stayed the night, started again this morning and it was fine. It's obviously something to do with heel, or boatspeed when there's no 'vacuum' in the water pipes because the engine is not running.
The only thing I changed when I had the pump apart was one of the brass hose tails on the pump body. I noticed that it wasn't quite the right size for the hose connected to it, and it was also very short, so there had been some bodgery with rescue tape and sealant. I fitted a marginally wider (1mm OD?) tail which was longer and allowed 2 hose clips. I don't know if the bore of the tail was different though.
Could this have affected it? Why? Or is there some kind of bleed screw somewhere I need to open? The boat is fitted with a siphon lock thingy high up above the exhaust level, which in turn has a tell tale pipe which piddles out of the top sides.
Any help gratefully received! Thanks.
